Cooling Fan Replacement for 4.0L
TrueTexas
TX
I need to replace the cooling fan on one of my 1999 TJs with a 4.0L engine as one of the blades has a pretty decent bend in it.
My searches come up with a bunch of Dorman options. It seems the TJ fans are around $130 but the ones for a YJ are around $40.
Anyone know the difference between the fans and if there are other, more affordable options available to replace the fan?
My searches come up with a bunch of Dorman options. It seems the TJ fans are around $130 but the ones for a TJ are around $40.
I think you should get the 40-130 dollar one for a TJ.
Reactions: L J
@mrblaine damn autocorrect. The $40 one is for a YJ.
Haha - At least my spell check knows which Jeep is the only one we should be talking about
TrueTexas - Is the bend bad enough that it can't be hammered back into shape?
Reach out to Davey ay Davey's Jeeps, should have a replacement fan available. Do a parts request as not everything is listed on the page.
https://daveysjeeps.com/
It could be bent back which would improve it slightly but my concern is that an unbalanced fan will put stress on the water pump causing it to fail.
Thanks @Jodh and @TJ4Jim. I hadn't thought about going that route. I've bought random screws and stuff from Davey's in the past. Great idea!!!
Why would it be out of balance if you bend it back?
The service manual is pretty specific on how to check the balance and what constitutes good from bad. The problem is that one of my fins is bent at the bead along the fin and although bending it back will improve it, there is no real way to get it back to spec. If a replacement fan was around $40, it's a no brainier. At $130, it's a little more painful. Especially since this is on my second TJ that I barely have driven in the past year
