Hello,
I have a Tj 4.0 with automatic transmission model 32RH A904 (as per Chris's post regarding car specifications).
My problem is that: After starting the car, when I want to shift from park (P) to drive (D) the car wants to pull forward with great force - It's practically as if I had the drive gear on and pushed the gas to the max... and again I want to point out that this happens when the car is parked and I want to shift into drive.
The oil in the gearbox was changed, I also had the torque converter checked. The torque converter is supposedly ok, but from what I was told it has been modified before.
... so my question is: Have You encountered a similar problem or what could be wrong?
Thanks a lot for help, Martin
