Working on an LS swap and won't be running the 2004 TJ cluster. I feel like powering the courtesy lights should be easier than I'm finding it to be... There's zero issues if the cluster is plugged in, so I take that to mean I don't have an issue with the circuits. Right now I just want to apply 12v power to the courtesy lights and bypass the multifunction switch.
Any tips?
- I'd have thought I could apply 12v to pin 5 of cluster C2 but pin 5 already has 12v at it.
- Grounding pin 5 via test light doesn't turn on the courtesy lights (only the bulb in the test light.).
- Pin 6 goes to ground.
Any tips?
