SOLD Covington, WA, USA - 2003 Jeep Wrangler, 111k miles, for sale for $14,000 - lots of extras (8.8 conversion, regear, ARB air locker, and more)
PNWBrian
Covington, WA
Price
14000
Covington, WA
Garage kept 2003 Jeep Wrangler 'X' model TJ with a clean title.
Cruises great on the road and on the trail.
Heat and A/C both work great.
Highlights: ARB rear air locker, front LSD, 4.88 gears, 8.8 rear axle swap, new axles, and tires, all with only a few thousand miles on them.
Solid frame and lots of mechanical work done 2019 to 2021 (most of it at Auburn Car Repair and Offroad)
Autotrader ad with vehicle history report: Used 2003 Jeep Wrangler 4WD X for sale in Kent, WA 98042: Sport Utility Details - 590217540 - Autotrader
Facebook ad: https://www.facebook.com/marketplace/item/563245918393689/
Axle/Gearing work done May 2020 at 108k miles.
Rear Axle:
Ford 8.8 31 spline with Artec 8.8 truss/bracket kit
Yukon Ultimate 8.8 Axle shaft kit and Master Overhaul kit
Yukon Ring and Pinion set 4.88 Ratio
ARB Rear Air Locker
New rear disc brake rotors, calibers, pads, and hoses
ARB Red Diff Cover
Front Axle:
Dana 30 front axle
Yukon Ring & Pinon set 4.88 Ratio
Eaton Detroit Truetrac limited slip differential
ARB Red Diff Cover
Other items:
ARB Single Compressor 12V installed on driver side fender under the hood
33" Cooper STT Pros (Installed at 106k miles)
4-inch suspension lift
RANCHO RS9000XL Adjustable Shocks
JKS 2001 Front Swaybar Quicker Disconnect System
Banks Ram-Air cold intake
Banks Exhaust system
Off Road Steel Flat Front & Rear Fender Flares Guard
Rock Rails
Smittybilt XRC Front Bumper
OFFROAD BOAR Synthetic Rope Waterproof Winch - 13000 lb. Load Capacity
Smittybilt SRC Rear Bumper w/ Tire Carrier
Rough Country 6 Button Multiple Light Controller
Nilight 4Inch Lights 60W Flood Spot Combo on Front Bumper
LED Headlights
Arizona Rocky Road Radio Mount
2 RAM 1” ball mounts on dash for phone, tablet, etc.
Pioneer Stereo with Bluetooth, aux port, USB, CD/MP3 support
Terraflex Rear Antenna mount on passenger side brakelight
Odyssey 34-709 Battery
New battery wiring from CustomBatteryCables(dot)com
Tuffy Locking Glove Box
Tuffy Trunk enclosure (between backseat and tailgate)
Tailgate drop down table
HiLift Jack mounts across back roll bars just behind backseat (Jack not included)
BEDTRED Interior Liner Front and Back (Made by Bedrug) installed 2019.
New Side Mirrors
New driver/passenger outside door handles
New soft top, frame type. Installed 2019.
Mesh shade top.
Neoprene seat covers on front and back seats.
Smittybilt external frame roof rack, can support a Roof top tent.
Maintenance work done 2019 to present:
New power steering pump and pressure hose
New Starter
New fuel pump
New rear main seal and oil pan gasket
New Valve Cover Gasket
New Transfer case rear output seal
A/C recharged and checked for leaks (none found)
New Spicer Universal Joints for front axles and driveshaft
New ball joints in front
Fluids, oil, etc. changes at required intervals
Odyssey battery kept on a trickle charger when vehicle is not in regular use
Items to be aware of:
Windshield has some pits and chips (no cracks)
Body has a couple small dings and chips
Stereo works, but speakers are not great
Frame is in great shape, does have some minor surface rust (no internal rust, spent most of its life in Nevada before WA)
+14
Reactions: Vasq
