W woodschip Member Original poster Supporting Member Joined Jan 23, 2020 Messages 29 Location Cookeville TN Jan 16, 2021 #1 Is a friction modifier needed for my limited slip rear Dana 44 in my 04 LJ ? Thanks
pcoplin TJ Enthusiast Supporting Member Joined Dec 1, 2018 Messages 589 Location Santiam, OR Jan 16, 2021 #2 Is it the factory TrackLok? Then yes, you will need to add modifier. If it's aftermarket, it depends.
bromel TJ Addict Supporting Member Joined Oct 11, 2018 Messages 1,013 Location Montauk, NY Jan 16, 2021 #3 Basically any synthetic gear lube will have the friction modifier built in.
W woodschip Member Original poster Supporting Member Joined Jan 23, 2020 Messages 29 Location Cookeville TN Jan 16, 2021 #4 Thanks for your speedy reply . Happy Trails !!
Rubicon88 TJ Addict Joined Sep 24, 2020 Messages 2,400 Location Western PA....Altoona area to be exact. Jan 16, 2021 #5 woodschip said: Is a friction modifier needed for my limited slip rear Dana 44 in my 04 LJ ? Thanks Click to expand... Run mobil 1 75-140 and forget about it. No whale sperm needed. Reactions: BlueChip
