Dash light bulb part numbers
LONGJP2
TJ Expert
Lifetime Supporting Member
S. Illinois
Specifically, I'm looking for OEM part numbers (or a link) for the HVAC bulbs, and the 2 that go in the switches..
All 3 are similar but different.
Not looking for LED replacements.
It's either Mopar p/n 04874349 or L000PC74. The Mopar Parts Guide shows both for the 2006 instrument cluster without saying which is used where.
IIRC
The bottom of the switch uses a large base with a large bulb, with a blue cover over it.
The top of the switch uses a small base with a small bulb.
The HVAC uses a large base with a small bulb.
So, while you could put an HVAC bulb in the bottom of the switch, the blue cover won't stay on the smaller bulb.
The Mopar parts guide doesn't show the bulbs inside the HVAC control module, I was just thinking one of the two instrument cluster bulbs could be the same.
I found several part numbers listed.
Some mention the switches in their description.
04874349
05183278AA
04874122AB
04874123
74
103
194
Plus, on the originals, the bulbs do not pull out of their 1/4 turn bases.
