Death Wobble
Twopoint
TJ Pupil ... and all it entails...
Lifetime Supporting Member
Kitsap WA
finally discovered what the dreaded death wobble is all about... and I don't like it one bit.
I had to almost stop the jeep to get it to stop.
when I got home and did my inspection I found that it looks to be a combination of front track bar and a bunch of bad tie rod ends.
So .. swapped out the old front track bar with an adjustable JKS, luckily was able to reuse the old bolt holes as the PO had drilled a new hole. which was quite Oval,
... waiting patiently for all the moog parts from Amazon
90323
Yep, that there will do it!
It's a real scary, eye opening experience, that's for sure.
People who think their tire vibrations are death wobble have no idea what real death wobble is ;)
That is a no Shitter my friend! after I pulled over to the side, the first 5 minutes were getting my hear under control.
Dont worry about the ovaled hole, the track bar is held by the correct torque specs.
Reactions: Twopoint
