I have the Derale in my 2003 tj and its done a great job. Problem I'm doing a 4-link long arm stretch in the rear and it's going to be in the way. At least it looks like it. Has anyone found an alternate location for it? I really want to keep it.
I have an air tank in the location that their kit goes. I bought the cooler and fabbed my own brackets to put it under the tub but further back, mine is mounted directly below the back seat. Mine is an LJ so I may have more room to play with.
Jeep is outside and it’s snowing, I’ll get some when I can.I'm thinking about moving mine back too. Plenty of room on the LJ.
Got any pictures?
I looked at the kit. Its basically what i'm doing. Removed mine from the frame bracket and am mounting right behind the drivers seat underneath the tub. plenty of room there@RD3 I used the Derale 13950 kit
Chris, you would think but the upper control arm goes directly through the spot that the cooler was hanging. Moving further backEven with a 4-link, there should still be room to mount it under there, no question about it.
