Die grinder bit recommendations
red02tj
TJ Expert
Atlanta
Need some recommendations for die grinder bits and discs. Picked up the m12 fuel die grinder, I know my drill wire wheels aren’t safe to use. Looking for a few suggestions to get started for frame cleanup, general rust removal and around the house work.
I have no recommendations here - I don't use any of my die grinders for that.
Here are my recommendations:
  • Carbide bits are great for detail work when removing material. Double-cut for soft metals (i.e., aluminum), single-cut for harder metals (i.e., steel).
  • Jimmy Shine Death Wheels for cut-off work (hat tip to @mrblaine for that recommendation), but I've never been able to find them anywhere.
  • 3M Roloc Bristle Discs for gasket removal (but the dust is still abrasive, so be sure to cover sensitive bits and vacuum up the mess left). They come in three different grits. The softest is best for aluminum, and the other two work good on steel.
  • I really like this radius bit, which works like a router bit: Pferd 25149
I checked with the company, they pointed me to the replacement versions. We've tried them and so far they seem to be the same or very close. I have a care package headed your way so you can try them and see what you think.
  • Love
Reactions: NashvilleTJ and sab
Thanks, Mr. Blaine!
