Ok guys and gals I have a 2000 Wrangler 4.0. Do I have to use a full syn motor oil or can I use a blend. I'll be using 10w30 and the TJ has 50k on the odometer. Thank you for your help
Awesome, thank you. It says to use a syn on it but its a 2000, I cant imagine that engine needs full syn. I just wanted to know that if I used conventional if it would be safe for the engine.Oh boy, you will get 5000 different answers on this. Personally I use any high mileage 10w30 that is for sale, valve line, Mobil one, doesn't matter for me.
Many say full syn oil will promote leaking but I’m not sure if thats true. But I would only use a full syn oil if you live in a place where it gets really cold, other than that conventional or a blend is fine. The 4.0 engine isn’t really picky on oil
I thought it was odd that people were saying using a synthetic for a 21 year old Jeep. I figured conventional would be ok, Thank you for your timeI personally choose to use a conventional. I would only switch to a synthetic if I moved to an extra cold location like North Dakota or Minnesota.
While we are heading into summer... D.C. is in my hip pocket and still gets cold in winter.You don’t need to use synthetic at all, nor should you unless you have a special case (super cold winters for instance).
Just put regular old oil in it, these things aren’t picky.
I appreciate the response. Just wasn't sure if Jeep calls for a full syn on a Jeep that is 21 yrs oldSynthetic blend...
LOL...
Not laughing at you but seriously...
In a day when you can buy an oil change jug of full synthetic for $20 ... or 3.49 per quart of full synthetic...
Come on!!!!!!
Get some full synthetic 10w30 (whatever the hell brand you want) and fuhgetaboutit
DC here tooWhile we are heading into summer... D.C. is in my hip pocket and still gets cold in winter.
Regardless, for as cheap as full synthetic is........![]()
Considering how cheap full synthetic can be had....why not?I thought it was odd that people were saying using a synthetic for a 21 year old Jeep. I figured conventional would be ok, Thank you for your time
Awesome man. I am going to change it every 3k anyway so I figured a 21 yr old Jeep doesn't need a full synYou don’t need to use synthetic at all, nor should you unless you have a special case (super cold winters for instance).
Definitely not, any off the shelf oil will work just fine.Awesome man. I am going to change it every 3k anyway so I figured a 21 yr old Jeep doesn't need a full syn
Yes!Definitely not, any off the shelf oil will work just fine.
I haven’t priced it out in forever, has it come down in price a lot?
No. We lifted the ban in 2018 on conventional oil.Ok guys and gals I have a 2000 Wrangler 4.0. Do I have to use a full syn motor oil or can I use a blend. I'll be using 10w30 and the TJ has 50k on the odometer. Thank you for your help
It doesn't.I appreciate the response. Just wasn't sure if Jeep calls for a full syn on a Jeep that is 21 yrs old
