Front windshield washer pump of my 2004 TJ stopped spraying. I can hear the pump working but the no fluid is coming out of the line. Does this sounds like I have to replace the pump?
That's my guess too, likely a calcium buildup inside the squirters from hard water. Pull the hose off the squirters and see if the pump squirts through just the hose.The squirters could be clogged. This is common
Happens all the time on my vehicles. One or both of the nozzles will get clogged. Sometimes it’s carnuba wax too.That's my guess too, likely a calcium buildup inside the squirters from hard water. Pull the hose off the squirters and see if the pump squirts through just the hose.
I did that and still no water coming out of the hose.That's my guess too, likely a calcium buildup inside the squirters from hard water. Pull the hose off the squirters and see if the pump squirts through just the hose.
I’ve actually removed the hose from the pump (water continuously flaws out of the pump without the hose) and blew through the hose and water came out to the other end. Put the hose back into the pump and turned the pump on but no water comes out to the end of the hose.First ensure there is enough water in the reservoir.
Then trace the rubber hose from the pump to the nozzles; there is a coupler inline that is a check valve. '
Disconnect the coupler on the inlet side and test to see if what comes out.
If water comes out then reattach the hose and disconnect on the outlet side and test again. If no water come out then the check valve could be stuck closed
Alright. I will those and let you know what happens. Thank you for your time.With those problem areas verified not to be the problem; it would appear the pump has a problem.
The reason why I ask about the check valve; the previous owner of my Jeep installed the check valve backwards and burned out the pump.
