I don't believe so. (But I could be wrong.) Power is controlled by a relay under the hood. It should just get constant 12 volt power. When you turn the ignition to "run" or "start", power is fed to the relay from the ignition switch, which in turn sends power to the fuel pump.Does the PCM control power to the fuel pump some how???
Did you ever find a solution? I swapped the FUEL PUMP RELAY and the FUEL PUMP. Still same issue. The Fuel pump will run in accessory mode (Key turned on but not to start) for a long time. I turn it off, then proceed to turn it back on. The fuel pump runs, connects to relay (im assuming) and the Gas Gauge and Battery Gauge start to turn in the appropriate area. Then I can finally turn my jeep on.. Now that its colder, its taking about 30min to an hour for the gauges work.On mine when you turn on the ignition but don’t start the engine the pump will run for a couple of seconds until the pressure comes up and then shut off. So something is controlling it.
That might be related to the ASD relay or circuit. Try swapping the ASD relay first and see what happensDid you ever find a solution? I swapped the FUEL PUMP RELAY and the FUEL PUMP. Still same issue. The Fuel pump will run in accessory mode (Key turned on but not to start) for a long time. I turn it off, then proceed to turn it back on. The fuel pump runs, connects to relay (im assuming) and the Gas Gauge and Battery Gauge start to turn in the appropriate area. Then I can finally turn my jeep on.. Now that its colder, its taking about 30min to an hour for the gauges work.
Appreciate the suggestions. I changed all the fuses under the hood and glove box.That might be related to the ASD relay or circuit. Try swapping the ASD relay first and see what happens
