Does this look like a typical Dana 44 setup?
I'm 99% sure that it will use the same cups that the standard Dana 44 uses. If someone can come up with an OD of the cup, I can measure the one I have and see if it will fit. Or, if I think about it, I can dig it out and measure the journal size.
Would you possibly be able to look over my part list before I pull the trigger? I know your very experienced with quality parts and would highly appreciate your opinion on the parts I need to buy. I'd hate to buy a bunch of crap that doesn't fit or ain't gonna last. I know its long but its all I can find
G2 gear and axle #s
G/2 1-2033-489 ring & pinion
G/2 25-2033 install kit
G/2 40-2033AL diff cover
Dana/Spicer #s
2-4-8091x 1310 yoke
2-94-28x straps and bolts
36797 axle bearing retainer
47160 axle seal retainer
35239 outer axle oil seal
50660 pinion seal
565903 axle shaft bearing
Timken #s
104949/104912 carrier bearings x2
02820/02872 pinion tail
31520/31594 pinion head bearing
Carrier #s
ARB RD109
G2 gear and axle #s
Dana/Spicer #s
2-4-8091x 1310 yoke
50660 pinion seal
Timken #s
Carrier #s
ARB RD109
Drum brakes instead of discs?
I'm not wholly familiar with whether the part numbers are correct but if they are, I'd use them. If you play in the rocks, that aluminum cover is questionable.
Wrong axle seal retainer then. You want the Spicer 51762 instead of the flat one. Given a choice, I prefer the Timken 9912S axle oil seal. The expandable skirt seals better than the two little ridges.
See thats why your the man right there^ squaring me away and shit. Lol thanks
