Just replaced the outside door hanle on my 06 li. Accidently shut the door it will not open. Inside handle or outside handle. How can I get it open? Help!!
Just for clarification, I don’t mean can you open the door, but does the lock sound / feel like it is actuating? Trying to narrow down if the lock is engaged and not actuating or if the latch release mechanism is disconnected.
The outside handle moves as expected. The inside handle moves as expected. The door lock will not disengage with the key or the inside lever. If I could get it open i would disassemble everything and start over. Anyone know how to get it open in this situation?
I figured it out. I unhooked the interior handle lock rod, and removed the exterior handle hair pin that holds the outside handle rod. I was able to open the door using the interior handle. made sure both lock mechanisms were in the unlocked position. Reassembled. Works perfectly. Thanks for the suggestions.
