Drain plugs
Allen Faifer
I was curious if anyone has removed the hard plastic drain plugs in their floor board? tried prying them up with a screw driver but they just seem to deform and I don't wanna damage them and not have plugs anymore. Maybe I can push them out from the bottom?
The rubber plugs in the front footwells are designed to be removed from the top, I never had trouble removing mine so just keep at it... no need to push them out from underneath. There are some things that look like drain plugs in front of the back seat too but they're not drain plugs, they only plug holes used during vehicle assembly.
Ok, i got the rubber plugs out no problem. I was unsure if the plastic ones were removable. I guess I'll drill some new holes for plugs in the rear floor boards.
