@bobthetj03 Ha, Ha, my Vibes are gone...How are yours?
Seriously though, I had an extra day of vacation planned before I left on my trip to Drummond Island. I spent the morning on Honey do items, and the afternoon on the jeep. Took some good measurements of the rear drivetrain. When I started...
My Tcase was at 10.1°, my driveshaft was at 14.9°, and my Axle was at 9.1°. That gave me an operating angle of 4.8 at the T-case joint and 5.8 at the rear joint. Its within one degree, so probably OK, but its pushing the limits.
I also wiggled my Axle side U-joint and it had a bunch of play in one direction.
So, what did I do. Well, I didn't like the difference in angle, so I added about a 1/2" of spacer (8 3/8" washers) between the transmission and the transmission mount.
My new drivetrain angles are 9.3° at the T-case, 15.7° on the Shaft, and 9.1° on the Axle...which gives a T-case operating angle of 6.4 and an axle operating angle of 6.6.
I also replaced the U-joint that was bad. Found a broken needle bearing in it!
Went out for a test drive, and everything is Nice and smooth again. If it wasn't such a pain in the ass to put those washers in, I'd pull them and take a drive, just so I know if they make any difference. Thanks for all your input.
