The Super is an upgrade kit for the Dana 35 that strengthens it so it can run larger tires and a locker.Not sure what the "Super" 35 is. I do have the 35 in the rear of mine.
The Super 35 is upgraded 30 spline axles (usually alloy) from the stock 27 spline axles and a locker of some sort. Usually a gear upgrade / ratio change as well, but that's just a knock-on and not really required for the "super" upgrade. The change from a 27 spline to a 30 spline axle is the money shot. It makes the Dana 35 much stronger and keeps the shafts from breaking. (lol, well, usually) The upgrade to a locker is required because there aren't any 30 spline carriers available for the Dana 35 that aren't an aftermarket locker.Not sure what the "Super" 35 is. I do have the 35 in the rear of mine.
Super 35 with an Eaton E Locker sounds awesome. Following this thread as I haven't heard anything about issues with the dana 35 e-locker only having 3 pinions.The Super 35 is upgraded 30 spline axles (usually alloy) from the stock 27 spline axles and a locker of some sort. Usually a gear upgrade / ratio change as well, but that's just a knock-on and not really required for the "super" upgrade. The change from a 27 spline to a 30 spline axle is the money shot. It makes the Dana 35 much stronger and keeps the shafts from breaking. (lol, well, usually) The upgrade to a locker is required because there aren't any 30 spline carriers available for the Dana 35 that aren't an aftermarket locker.
A Super 35 kit is one way to beef up a TJ rear axle to support bigger tires, a locker and more abusive off road conditions. I happen to like the idea of keeping my Dana 35 in the rear for the conditions that I wheel in. It's a lot of bang for the buck and not overkill. Some go with a Ford 8.8, Dana 44 or Dana 60 rear axle. Those tend to be more work and expense unless you happen on to an already set up Dana 44 out of a TJ for a good price. Rare, but it does happen.
I kinda figured that's what it was. I don't beat my Jeep and go slow and easy with it, so that's why I figured I could get by with the Dana 35 with the E-locker. But I was reading several articles in here and for a peace of mind thinking about putting different axles in it. Is it too late since I already put the locker in it? I also went down to 4:56 gears. I think I still have the 27 spline in it.The Super 35 is upgraded 30 spline axles (usually alloy) from the stock 27 spline axles and a locker of some sort. Usually a gear upgrade / ratio change as well, but that's just a knock-on and not really required for the "super" upgrade. The change from a 27 spline to a 30 spline axle is the money shot. It makes the Dana 35 much stronger and keeps the shafts from breaking. (lol, well, usually) The upgrade to a locker is required because there aren't any 30 spline carriers available for the Dana 35 that aren't an aftermarket locker.
There are chromoly 27 spline axles available that are stronger. If you want to run the 30's you have to buy a new locker.I kinda figured that's what it was. I don't beat my Jeep and go slow and easy with it, so that's why I figured I could get by with the Dana 35 with the E-locker. But I was reading several articles in here and for a peace of mind thinking about putting different axles in it. Is it too late since I already put the locker in it? I also went down to 4:56 gears. I think I still have the 27 spline in it.
The main spider shaft is retained by the third spider shaft and a snap ring. It is actually a pretty good design as it eliminates the cross bolt other C clip riffs use.
And each shaft end has a spider gear attached to it, correct? That’s how I have mine currently reassembled, after the disc brake conversion, but wanted to make sure it was right.
Yes spiders ride on end of each shaft.
