Electrical gurus need help
Blackout
Austin, TX, United States
Ive been dealing with this issue for awhile now and cant seem to find out what is causing all my lights to flicker. Any help or suggestions?
TIA
Sent from my SM-G935T using Tapatalk
I would suggest to check battery cables first. Clean and tight.
If they are good I would suspect the alternator. A shop that can do a charging system test could probably verify (not sure AutoZone types can do more than check charging voltage).
Another option is to wire a bulb across the battery terminals and see if it flickers too, if it does that would eliminate electrical noise from anywhere else on the vehicle and indicate the alternator.
a lot of time a bad ground from one of the lights is not grounding properly, then system backtracks to find a alternate ground causing lights flicker and some times not operating at all
Most individual lights use their own ground. If the flickering is consistent you can remove 1 bulb at a time until the flickering stops. That should tell you about where the problem is.
