Engine light blinking
Unlimited
Long Island
Hi all, in recently purchased a 2005 unlimited, motor stated sputtering and then died, got it started then died again, finally made it home on higher RPM, noticed the engine light blinking
You need to have it scanned for codes with an OBDII scanner.
Well you have several things going on there and alot to attack all at once with little history.
....first of all I would recommend you get a obdii reader/scanner.
But if it were my jeep, i would disconnect the negative battery cable for 10-15 minutes, then reconnect.
Drive the jeep as usual and watch for codes as they come up and attack them one at a time.
This way the PCM will let you know what is priority if/when codes return.
Reactions: Unlimited
I did that today after work, took it to run errands and nothing so far... thanks for your input, I appreciate you all...
Reactions: KCsTJ
