Hi All,
Just joined up, bought myself a 2004 4.0 TJ xtreme sport (which I believe is the columbia edition in the states) and on purchasing noticed the headlights were acting strange, there were no low beams, only high. Ended up needing a new multifunction switch which has been changed out and headlights all working all okay, but now but I've no rear fog light now.
Any suggestions?
Bulb fine, brand new switch. Connection looks fine on the back of the fog. Dont even get anything on the dash when turning on the fogs, rotate onto side lights and pull out. Same thing on headlights. Makes me think its not even trying to come on as there's no fog light symbol on the dash coming on.
Bulb looked fine, connection on back of switch looked fine, connection rear of fog looked fine, switch brand new.
Not sure where to start with this one, i'm a bit stumped.
Switch that was fitted
https://www.amazon.co.uk/dp/B0BM8PWDK2?tag=tjforum0a-21
Edit - Think I may have messed up, i've stuck a multifunction switch part number 5016709AD (front fogs), on when I needed part number 05016710AD (rear fogs), will it be possible to switch the wiring/pins to work correctly? It doesnt seem possible to buy 05016710AD anywhere.
Any suggestions?
