Also make sure to check metal line running from hose connection from tank running inside drivers side frame rail up to under drivers floorboard in engine compartment where it returns back to rubber hose coming up to evap on drivers inner fender well. I found some corrosion on mine where it goes up over rear axle and down in and around rear control arm bracket when I pulled tank to change out skid plate. I cut it out and put a piece of 3/16" brake line with a couple pieces of 3/16" vac hose as connectors and ordered some new 3/16" rolled brake line to run entire new 1 piece front to back. Very cheap and easy to do. IF you need it, or just want to refresh those lines. Figure 20yrs under there in the elements will take it's toll on those as it does everything else under a Jeep. And brake line is right there with it so while your at it.
You know how that goes.
I actually ended up with a 4 pk of tubing(like 100' for $24) way too much but never hurts to have extra. But here's enough for $10 to do front to back new and fittings thrown in.
https://rover.ebay.com/rover/1/711-...0001&campid=5337789113&icep_item=291697244318
Also just used a simple cheap spring bender and with this line being easily bendable I had no problems putting it where it needed to be.
A set like this, even though I have a regular tubing bender these worked much easier as I started at front and just let the spring ride back the line bending it where needed. Just remember to pre route your tubing over tranny skid plate,rear axle and around thru any brackets first. Then go back with bender and straighten and tighten,bend as needed to fit into frame clips already there holding old line. Pop out old pop in new.
https://rover.ebay.com/rover/1/711-...0001&campid=5337789113&icep_item=183781927938
Anyhow just throwing that out there for anyone who may not have thought about that line and are only looking for racked rubber hose connections leaking throwing codes.
