Is your rear axle centered? I did a small lift as well, and immediately got the same symptoms. Shudder in first gear, and some vibrations at certain speeds.
Dropping the transfer case about an inch solved the vibrations, and greatly reduced the shudder. I'm going to put an adjustable track bar on the rear to get the axle centered and I believe that will fix it.
