Fog wire harness help
red02tj
TJ Expert
Atlanta
I know enough that the PO wiring for the fogs and light bar were no good so I’m trying to re wire it correctly. I have a pair of KC halogen knockoffs. Will this harness work correctly? Light bar is not going back on
Nilight - NI -WA 06 LED Light Bar Wiring Harness Kit - 2 Leads 12V On Off Switch Power Relay Blade Fuse for Off Road Lights LED Work Light, 2 Years Warranty https://www.amazon.com/dp/B071ZPX32N/?tag=wranglerorg-20
Thanks.
That would work fine but if your KC Halogen "knockoffs" are LED, you don't need a relay (which is in that wiring harness kit) to run them. A simple on-off switch would work fine for LED lights. I'd only run that wiring harness kit with its relay if your lights have conventional incandescent bulbs.
Reactions: red02tj
Halogen and thanks as always.
Reactions: Jerry Bransford
