Gas Tank Evap Port Replacement
XCRN
Springfield OH
Is there a such thing as a replacement for these evap ports on the gas tank it self or even new stock replacement tanks available? Or am I SOL and need to plug it or buy a used tank. I do not live in an emission check state so I could just cap it, but I would not mind having the evap system functioning properly.
Careful dremmel work and sacrifice a pen... Find a plastic pen with the same OD as the evap port ID. Epoxy weld. That's how I had to do mine as tank evap ports are not serviceable.
Reactions: RobertJ
I've never seen a replacement from Mopar for these pieces. However, I'm sure someone knows of something you can replace them with. @mrblaine, surely you have a solution for this, no?
