Grinding when I put my Jeep in 4-low
How are you going into 4-low? Are you doing it at a stop or a 1-2mph roll? Are you going into neutral first, then into 4-low?
Hmmm, sounds like you're doing it right then. Your transfer case shifter linkage in that case might need adjustment.
Try rolling first then shift into 4-lo. Doesn’t always work from a dead stop
This exactly, and it's how I do it. If I am at a dead stop it sometimes grinds when shifting into 4Lo. I nearly always shift into 4Lo while at a dead-slow roll with a quick firm pull into 4Lo. If I was rolling any slower I'd be stopped. A dead slow roll allows the gears to mesh more consistently by one side turning dead-slow.
Reactions: Daryl
I am at a stop, neutral then 4-low
Read the Manual, you should be moving, 2-3 mph.
Shifting Procedure
2H to 4H or 4H to 2H
Shifting between 2H and 4H can be made with the
vehicle stopped or in motion. If the vehicle is in motion,
shifts can be made up to 55 mph (88 km/h). With the
vehicle in motion, the transfer case will engage/
disengage faster if you momentarily release the accelera-
tor pedal after completing the shift. Apply a constant
force when shifting the transfer case lever.
4H to 4L or 4L to 4H
With the vehicle rolling at 2 to 3 mph (3 to 5 km/h), shift
an automatic transmission to N (Neutral) or depress the
clutch pedal on a manual transmission. While the vehicle
is coasting at 2 to 3 mph (3 to 5 km/h), shift the transfer
case lever firmly to the desired position. Do not pause in
transfer case N (Neutral).
NOTE: Pausing in transfer case N (Neutral) in vehicles
equipped with an automatic transmission may require
shutting the engine OFF to avoid gear clash while
completing the shift. If difficulty occurs, shift the auto-
matic transmission to N (Neutral), hold foot on brake,
and turn the engine OFF. Make shift to desired mode.
NOTE: Shifting into or out of 4L is possible with the
vehicle completely stopped, however, difficulty may oc-
cur due to the mating teeth not being properly aligned.
Several attempts may be required for clutch teeth align-
ment and shift completion to occur. The preferred
method is with the vehicle rolling at 2 to 3 mph (3 to 5
km/h).
Avoid attempting to engage or disengage 4L with
the vehicle moving faster than 2 to 3 mph (3 to 5 km/h)
