Yes just got them today. No issues with the full doors i’ve used previously. No issue getting the pins to drop through. The other side fits fineWhat's the back story here? Did you just buy these half doors? Any issues with the doors that they're replacing? Did you have a hard time getting the pins on the half door to drop through both hinges? Does the other side fit fine?
Not yet. Will try that next if nobody has any other ideas.Did you loosen the hinges and try to adjust them that way? That's what I had to do to mine.
That is the way to fix it, all doors have to be adjusted to each individual Jeep.Not yet. Will try that next if nobody has any other ideas.
Thanks. Do u think i should heat the bolts on the hinges before attempting to loosen?That is the way to fix it, all doors have to be adjusted to each individual Jeep.
Loosen the hinges just slightly, move the door up or down till it closes, the snug the hinges down and try the door again. Took me all of 5 minutes to do both my doors.
Probably wouldn't hurt, looks like they still have factory paint on them, or insert the torx bit and whack it with a hammer.Looks like the lower hinge is stopping the door from setting all the way down. As the others have said, loosen the lower first and see if she drops down. If not loosen both hinges and align as needed
I tried one of these but never got the screws to move. I went to my electric impact wrench and the screw came out. Since the first one went like that I repeated the process on all screws. Started with hammer and manual impact tool then finished with electric. Got them all out.The cheap impact but a great way to get it done.
https://www.amazon.com/dp/B07R96M9VW/?tag=wranglerorg-20
Now post pictures of those mismatched 1/2 doors!!!!!Got it! Thanks everyone.
Gladly!Now post pictures of those mismatched 1/2 doors!!!!!
Looks awesome!!! According to @AndyG and he will have to quote all the particulars from the book, yes you are in the club!!!!!!
I’ll run it by Chris. He’s been tightening up lately.Looks awesome!!! According to @AndyG and he will have to quote all the particulars from the book, yes you are in the club!!!!!!
Man sorry Kiwi, it was probably my mismatched 1/2 doors that caused this.I’ll run it by Chris. He’s been tightening up lately.
