My 2006 TJ has a hard start when cold like the one picture in the video attached. However, after it starts once and heats up, it will start normal. Any ideas what this could be?
No check engine light. It has a long start when it’s cold, but once it starts and runs for a little bit and turn it off and then go to start it again, it starts fine. Could it be a bad fuel pump?
That’s crazy.. how cold is cold?.. maybe water in ur fuel?..try some fuel additive or maybe stay away from the low price fuels an see if that changes anything
Turn the key ON, but don’t start. Let the fuel pump run unti it stops running. Turn key OFF.
Repeat this a couple times, then start as normal. If it is a fuel pressure buildup issue, this should help rule that out.
Hmm, just watched the video...it isn’t what I expected. Seems like an electrical/battery/starter related issue instead. Perhaps a short causing intermittent low voltage or something, caused by the lower temps.
I have this exact same issue as described by the OP. I've experienced this over my 2 years of ownership. Battery, alternator, and starter check out fine. Plugs are fresh iridium's.
OP, what did you end up narrowing it down to? A tired fuel pump?
