Hi all, Happy Holidays!
2005 TJ (LJ) 4.0 starting acting up. Really Hard to start unless I give it lots of throttle, once its started it idles ok, however when you give it some gas it surges. I replaced the TPS and that made no difference. I also replaced the fuel pump, I had bought it already before this issue came up as the Jeep is getting high in Milage so I was stocking up on Maintenance items. Also changed the plugs as they were do for a change. I'll clean the IAC after Christmas, another good item thingy to do, but from what I read on the IAC doesn't seem to relate to the problem I'm having.
The surging began first
The hard starting began a few days later
The speedo stopped working along with the hard starting.
I parked it for a couple weeks till I got to look at it, when I drove it to my shop the speedo started working again but the surging was still there, idle still good.
Now that I've done some work on it, speedo doesn't work again, surging and hard starting.
Checked for broken wires and bad grounds so far but haven't found anything yet.
Odd to have multi issues without it being something in common (bad ground) though it is possible I suppose I'm chasing separate issues.
Posting while I think on it and do some more trouble shooting.
Codes I got before I made any changes. Think the CMP is the cause.
Car Scanner ELM OBD2
DTC report
Selected brand: Jeep
============1==============
C1787
Raw code: 5787
ECU: 10
Status: Pending
============2==============
C1100
Raw code: 5100
ECU: 10
Status: Pending
============3==============
P3700
Raw code: 3700
ECU: 10
Status: Pending
============4==============
U0E00
Raw code: CE00
ECU: 10
Status: Pending
============5==============
P0031
Raw code: 0031
ECU: 10
Status: Pending
OBDII: Heated oxygen sensor (HO2S) 1, bank 1, heater control - circuit low
============6==============
P0340
Raw code: 0340
ECU: 10
Status: Pending
OBDII: Camshaft position (CMP) sensor A, bank 1 - circuit malfunction
============7==============
P0129
Raw code: 0129
ECU: 10
Status: Pending
OBDII: Barometric pressure too low
============8==============
C17EE
Raw code: 57EE
ECU: 10
Status: Confirmed
============9==============
C1100
Raw code: 5100
ECU: 10
Status: Confirmed
============10==============
P3700
Raw code: 3700
ECU: 10
Status: Confirmed
============11==============
B2700
Raw code: A700
ECU: 10
Status: Confirmed
============12==============
P0031
Raw code: 0031
ECU: 10
Status: Confirmed
============13==============
P0340
Raw code: 0340
ECU: 10
Status: Confirmed
============14==============
P0129
Raw code: 0129
ECU: 10
Status: Confirmed
DTC report
C1787
Raw code: 5787
ECU: 10
Status: Pending
C1100
Raw code: 5100
ECU: 10
Status: Pending
P3700
Raw code: 3700
ECU: 10
Status: Pending
U0E00
Raw code: CE00
ECU: 10
Status: Pending
P0031
Raw code: 0031
ECU: 10
Status: Pending
P0340
Raw code: 0340
ECU: 10
Status: Pending
P0129
Raw code: 0129
ECU: 10
Status: Pending
C17EE
Raw code: 57EE
ECU: 10
Status: Confirmed
C1100
Raw code: 5100
ECU: 10
Status: Confirmed
P3700
Raw code: 3700
ECU: 10
Status: Confirmed
B2700
Raw code: A700
ECU: 10
Status: Confirmed
P0031
Raw code: 0031
ECU: 10
Status: Confirmed
P0340
Raw code: 0340
ECU: 10
Status: Confirmed
P0129
Raw code: 0129
ECU: 10
Status: Confirmed
