D David berd New Member Original poster Joined Jul 5, 2024 Messages 1 Location Minnesota Jul 5, 2024 #1 Wondering if anyone has had any luck using gasoline additives for leaking check valve in the fuel pump. I understand you have to remove the gas tank to replace fuel pump
Gilaguy23 TJ Addict Joined Sep 21, 2021 Messages 1,228 Location Kentucky Jul 5, 2024 #2 Is the pump whining? Have you tried just turning the key on a couple times to charge up the system? Did it help?
