Tonight I tried to remove my hard top for the first time since I’ve owned this specific TJ. I disconnected wiring harness and washer fluid hose, unhooked the front latches, and removed all of the rear bolts. Between my wife and I, we couldn’t get the thing to budge more than about 1/2” at the front end. Mind you we removed and replaced the hard top on our previous TJ several times so this wasn’t our first rodeo.
It was clear that the top had been removed previously because one torx bolt on each side was replaced with a 13mm hex bolt and nut.
After some inspection (to make sure we weren’t going crazy), it appears that there is a thin layer of foam, adhesive perhaps, between the top and the tub rails. It was too dark for a photo, but it was clearly there. I’ll try to get a photo with some light in the morning.
I’m thinking we’ll have to heat it up somehow in order to get them separated.
Has anyone ever come across something like this before?
