C
chalupasupreme
Guest
I'm installing hella h4 headlights into my TJ and the drivers side is still way too low even with the up/down adjustment screw fully locked at the highest position. The top of the drivers side beam cuts off on the ground maybe 20 yards in front of the car and I can barely see. The passenger side is fine. I pulled the light back out and saw the bottom positioning tab was bent in from shipping and straightened it out but it didn't make a difference. Is there anything else I should take a look at or something that could be stopping the screw from tightening more? I checked the housing and nothing is broken, I can see the position changing when I adjust the screw so it's not stripped or anything. Any suggestions would be appreciated!
