Hello everyone thank you for the add, I have had numerous TJ’s over the years and I am currently working on a 1997 sport six cylinder five-speed. The problem I’m having is with the dash lights and gauges sometimes they work fine other times they do goofy things including when I change the heater control from defrost to floor the dash lights change in different directions. I have had similar issues with the cluster before on a different jeep and I remove the cluster clean the pins and gave them a little tweak and everything was OK after that this one does not seem as if that is fixing the situation. I have checked and wiggled wires like crazy this jeep does not seem to have any aftermarket add-ons to where nobody has been into the harness at all any help would be appreciative. The hazard lights will come on at random and when I turn the fan on high they turn signal flasher makes a buzzing sound. When the fan works everything else works as well
