derekmac
My heater core has had a slight leak for the past 4.5 years I've owned it. I might do the bypass until the fall when the heat is needed again.
True enough, but then I gotta solder it together, blah, blah, blah. If it were $20, I'd think about it, but since its $10, I'll just go with the special hose.I really think you all are overthinking this, a piece of 1/2" copper tube and 2 hose clamps will do the trick.
Next dumb question: If I'm going to abandon the core and eventually replace it, why do I need to be concerned about capping it off?
With a slight leak, what were symptoms, other than coolant leak, how did you know it was heater core? I've been chasing a leak for a long time and it's getting worse. Good pressure tests and so on. Any info would be helpful.My heater core has had a slight leak for the past 4.5 years I've owned it. I might do the bypass until the fall when the heat is needed again.
It's still hot here so I'm not sure if I'd get fig or not, idk. I haven't been using ac to see if I'm getting anything from HVAC drain, nothing. I've heard that any leakage from core would go out drain rather than into passenger footwell, but again idk for certain, but it is dry.Smell, fog on the inside of the windshield, coolant dripping from the drain on the firewall behind the battery, coolant in the passenger footwell, that's all I can think of.
I had a new Stant cap that was sitting on my shelf for a few years, put that on couple of months ago, old cap definitely had bad spring. Stant looks good but I did just get another new Gates cap delivered from Amazon that I'm going to put on. I have the stuff to bypass core but want to do one thing at a time to isolate. I'm deciding which to do first.Radiator cap is good, especially the little spring and disc on the inside of the cap?
Coolant smell when the heat is on, and the very odd coolant drip out of the AC condensation drain.With a slight leak, what were symptoms, other than coolant leak, how did you know it was heater core? I've been chasing a leak for a long time and it's getting worse. Good pressure tests and so on. Any info would be helpful.
That is about what I've come to realize would be going on. I've never seen anything coming out drain but that doesn't mean anything, up until recently I've been looking for wetness inside the jeep but after reading up on it and asking questions found out that isn't necessarily the case.Coolant smell when the heat is on, and the very odd coolant drip out of the AC condensation drain.
