I drove the Jeep to a gas station and there was no problem cranking it. When I finished filling up the Jeep wouldn't start. Turned the key and nothing happened. Not even a click. Opened the hood checked the battery connections and they weren't loose. Literally tapped my finger on each connector. Got back in and it started no problem. Today I went to start it and same thing. Checked the connections again, nothing loose, and then tried to start it again. It started up just fine. I am wondering if this might be related to a different problem. Sometimes when I cut the Jeep off the radio turns back on. I have to cut the CD player off. This happens from time to time. What should I check? I am not a mechanic but have changed some stuff with success. I changed the multi-function switch months ago. I didn't change out the right side.
