- Joined
- Mar 1, 2016
- Messages
- 2
Hi,
I have a 2006 Jeep Wrangler TJ 2.4L 4-cyl (6-speed). In November my husband was driving home. Jeep was running fine. He stopped at a four-way stop and when he went to take off the Jeep died. He could not get it started after that... it cranks but won't turn over. We had it towed home and it has sat ever since.
The fuel pump appears to be working - we can hear it and it pumps fuel out when tested. We replaced the starter even though it tested fine (just to be sure). We replaced the battery. Eventually the codes and symptoms led us to believe the crankshaft position sensor might be bad (we replaced the camshaft position sensor in the summer). We replaced it and now we have codes that say there's a circuit A malfunction for both the CKP and camshaft sensor. We replaced the wiring harness to the CKP because my husband thought the wires looked cracked. However the wire colors don't match exactly so not sure it was wired correctly.
Any help would be greatly appreciated. We really can't afford to have it towed to a mechanic plus pay a mechanic to figure it out.
Thanks!
Michelle
Thanks!
Michelle
