I'm having trouble figuring out an IAC problem. The jeep is idling SUPER high, and I'm pretty much convinced at this point that it is sucking excessive air through the IAC port in the throttle body. I've bench tested the IAC...well, really I've verified that the stepper motor does its thing when you vary 12V/ground across the different pins. I have not exercised the entire travel of the IAC, but we've put in several including a known working one but nothing changes.
Removing the IAC from its home but leaving it plugged in also doesn't change anything. The IAC is fully drawn in, and running the jeep you can see the IAC plunger isn't moving.
Testing the voltage at the pins, I'm getting +/- 0.6V at some of the pins & 0.15V on some other combinations with the key on. We tested against another jeep and we see 12V at the plug, so it feels like the problem is right in there. We've verified continuity from the plug to the various pins at the PCM.
It seems like the PCM isn't supplying 12v to the IAC plug. But THAT is hard to verify.
I'll add that this is a fairly new PCM from @Wranglerfix so I wouldn't expect it to be the source of the problem. But I'm out of troubleshooting ideas.
