97 2.5 5 speed. Still chasing a few issues.
Currently doing the key turn to build pressure before starting.
It seems to run strongly if push through the gears aggressively. Just the rough idle and hesitation are driving me nuts.
Currently no codes but I've been disconnecting the battery while working.
Any suggestions?
BTW, I have a scanner Ancel BD310 on order.
- Rough idle - worst when cold
- Hesitation or skip under load. This happens between 2000 and 2800 rpms.
- Exhaust/Intake manifold
- Flushed/cleaned fuel injectors
- Replaced both O2 sensors - NTK
- CPS, MAP and TPS sensors (mopar)
- New plugs, wires, cap, rotor and ignition coil.
- Seafoam
Any suggestions?
