Take it from someone who has used one for years. Don't. There's way better solutions out there to any problem that a Hi-Lift can solve.
Oh that just not fair-—-blaming it on the poor beerThanks once again Jerry. Now my dull, alcohol soaked brain is 100% set on a winch. I get the sretch thing now with the straps, pathetically, thats what I have on board with a 2-ton puller.Only way that will work is with no straps and too much work. I shoulda known anyway, Ive used a trailer winch and poly rope to pull big rocks and trees and had to re-position lots of times. Further distance and more weight hits home now. Damn beer.
There is a time and place for them--however I haven't found it yet. Yes, I do have one. No, I don't carry it.
Don't lie. You've got it bolted to the top of your hood like a billy badass Jeeper (in Blaine's words)!
You just didn't place the jack in the correct location.I went to check my brakes last week and jacked it up as far as it could go and my 33's ended up about .25 inches off the ground.
Yes, please don't use high lift jacks.
I like that. The newer the Jeeper, the more likely he'll be absolutely certain he needs a Hi-Lift to go off-road. The more experienced at offroading a Jeeper is, the more likely it is he'll be convinced the best place for his Hi-Lift is at home in his garage.Slight editing
I can relateAlso I have dreams of somehow using it to jack up the ex wife's house and sliding it off the foundation in a river.
My stock jack was, jacked, so I bought a bottle jack from HF. Inexpensive and works fine. Something to consider if the stocker isn't working for you.I went to check my brakes last week and jacked it up as far as it could go and my 33's ended up about .25 inches off the ground.
Corrected.They are good for making you look like a hard core wheeler to beginners...
Same here, all my first bunch of cars had them with the sole exception of my '66 VW beetle. Detroit stopped including them for safety reasons, too many people were getting seriously hurt with them. I have vivid memories of how the cars would often sway some when up on those jacks, they were scary even back then when they were common. Those jacks have their uses but changing tires is not a good one.
