Horn is not working: Horn alternatives?
SafariRumbler
Tampa Florida
Hey my horn isn’t working and I replaced the clockspring and that fixed my blinker signal problem but not the horn. Is there a way I can wire up a push button horn on the dash. If anyone knows how that would be possible please explain. My horn itself works because if I plug it in it goes off.
A simple push switch running 12v to the horn is all you need. Pull the horn and check it is getting a good ground at the mounting bolt. Then run a jumper wire to make sure it isn't just the horn going bad. They can work intermittently as they break. Easy stuff first.
mine was the same and didn't work...got a relay from oreily 9.99 and it fixed it....yea now I squeak at people...
