Rob80x
It was junk and was all rusted out. It was scrapped.what did you do with the !" drop kit? would like to try, before I buy; see if it really helps or hurts...
Yup I had that problem too. Also hit it with PB Blaster.Better go ahead and order 6 new nutserts from Blaine. You'll probably have to end up cutting the bolts off and drilling out the nutserts.
Figure I'll add here rather than make a new thread. Just ordered some new nutserts from Blaine and I plan on cutting the heads/bolt body to get the spinners out for now. Now what to do about the rest of the bolt, I don't have access to a welder quite yet, so what I'm considering is using a pilot bit to get as close to center on the remaining bolt as possible, then drill out for the new nutserts. Anyone with more experience see a massive,besides lining up center, blunder or does it sound like a plan?
Also it's 2 bolts, right side front and center
Don't drill, as you don't want to risk oversizing the hole so the new nutserts don't fit right. Do grind down the protruding material (remainder of bolt and nutsert flange) with a flap disk on an angle grinder, then punch the remainder of nutsert into frame. Fish out nutsert and bolt with flex magnet from side hole of frame. Prep the frame area with paint or something to cover up the raw metal. Now you're ready to install fresh nutserts.Figure I'll add here rather than make a new thread. Just ordered some new nutserts from Blaine and I plan on cutting the heads/bolt body to get the spinners out for now. Now what to do about the rest of the bolt, I don't have access to a welder quite yet, so what I'm considering is using a pilot bit to get as close to center on the remaining bolt as possible, then drill out for the new nutserts. Anyone with more experience see a massive,besides lining up center, blunder or does it sound like a plan?
Yes. I painted the frame where I ground off the nutserts. I always paint/touch up the frame where I working.@taylormade73, in your post did I see You painted the frame and nutserts?
I don't believe it's necessary, Blaine mentioned they have a zinc coating. I did as it is standard practice for me to apply fresh paint when working on my jeep.Already printed the frame prior, was trying to decide whether a touch up on the nutserts would be warranted
If they spin the inserts have lost the grip to the frame. I used a chisel to wedge between the skid plate and the frame (hammerd in) near the spinning bolt. This wedges the insert tight against the frame. Loosen the bolt till it starts to spin again. Hammer the chisel/screwdriver to wedge it more and loosen again. Repeat till it's out. Then buy new inserts to re installNeed to get the the transfer case and need to remove the factory Skid Plate; however, the bolts seem to be seized inside the inserts and just spin the inserts.
Anybody else had this issue? And if so, how did you get the bolts out.
Worse case scenario, take a cut-off wheel and grind them off...
Just finished fighting with them myself. Had to cut off the two front most bolts. The other 4 came out. Replaced those 4 bolts with new ones and added lots of anti seize. Not going to worry about the two front ones right now.
