The Battery Temperature sensor provides information to the PCM to adjust the charge rate for the battery when outside air temperature is cold.
The problem you are experiencing may be as simple as the Battery Temperature sensor in the battery tray may be bad or the wiring for the sensor could be frayed or even broken.
You should inspect the sensor and its wiring to see if there a simple way to resolve your problem.
