Jerry Bransford No Longer Participating Supporting Member Joined Nov 9, 2015 Messages 29,734 Location Fleming Island FL May 25, 2020 #21 mrblaine said: Pull the old fluid out of the reservoir so you don't have to pump so much dirty fluid through the system. Click to expand... Something like a turkey baster works well for sucking the old fluid out of reservoirs like that. Reactions: BuildBreakRepeat
CharlesHS TJ Guru Supporting Member Lifetime Supporting Member Joined Mar 10, 2020 Messages 6,538 Location Jacksonville FL, Quezon Philippines May 25, 2020 #22 BuildBreakRepeat said: For anyone wondering - line wrenches (recommendation by Blaine) made quick work of the tube nut. Click to expand... I had used Line wrenches for years in the USNavy on hydraulic and air fittings instead of an open end wrench or crescent wrench. They get full contact on 4 sides of the fitting. For those that wonder what the Line wrenches look like.... Reactions: JMT, BuildBreakRepeat and Jerry Bransford
Jeep 541X Bend Jeepin' Supporting Member Joined Nov 2, 2020 Messages 322 Location Bend, Oregon Jun 1, 2021 #23 I should've read all of these posts before embarking on a brake-a-thon project...
