How to remove broken ignition?
Anne in Surrey
uk
Hi all, the ignition is broken so I cannot turn the key to run which would normally allow me to push the release button and slide off the cylinder. Any idea how I still could get it off so I can replace pretty please??
Use a slotted screw driver socket on a breaker bar and turn until it breaks. Remove a battery cable first.
Put the key in the ignition, hit the back of the key toward the steering column. You have to give it a good "whack", google it and you will find some examples.....
