SOLD HPD30 Axle
Sj's TJ
Vienna, VA
Price
$400
Northern VA
I’m moving up to tons and am selling my existing axles.
Front axle:
- High Pinion Dana 30
- 4.88 gears with Aussie lunchbox locker
- Savvy truss for mid-arm 3 link
- Artec LCA brackets trimmed for more clearance
- Reinforced track bar mount
- High clearance sway bar mounts
- Shock mounts for 1.5” width shocks (ran 12” fox shocks)
- Calipers/rotors/YJ hoses
What would these need done to fit stockish TJ?
For the rear, you would need to get the stock brackets for the upper CAs/track bar, shock mounts and sway bar (if you want). Barnes sells them pretty cheap:
https://barnes4wd.com/products/jeep-tj-oem-rear-axle-upper-control-arm-and-track-bar-brackets
https://barnes4wd.com/products/jeep-tj-lj-oem-rear-axle-shock-mounts
https://barnes4wd.com/products/tj-rear-sway-bar-brackets
For the front, you can delete the passenger side CA and just replace the driver side with one that has a standard 2.625" wide joint. If you have adjustable CAs it's just a new joint on the axle end.
If you have a welder and grinder, then the rear wouldn't take to much work as you only need to cut off the brackets on top of the truss, the shocks and the anti-rock brackets. Please let me know if you have any more questions.
Reactions: JMT
