Greetings from across the pond.
My wife dropped her 2000 TJ into a ditch due to some ice. There's not a lot of Wranglers over here so going back to the source!!
There are two parts of the fix that I need help with, the front right wheel rim got cracked and the bracket on the axle for the right hand lower control arm is bent.
Right side wheel base is about 5 to 8 mm shorter because of the bent bracket (about 0.3")
Wheel is 15", black version of this:
https://www.oewheelsllc.com/Jeep-New-Wrangler-Wheel-Silver
Is there a good cheap source of used wheels in the USA?
Regarding the bracket:
heat and straighten?
cut off, straighten reweld?
Can you get new brackets to weld on? If so where?
I'm coming over to the USA in a few weeks so I could probably bring stuff back (business trip....)
Thanks in advance,
Dave
Thanks in advance,
Dave
