Was or is there any trim pieces on the inside that run up the sides of the windshield ? I have 3 holes on each side that look like factory holes? I was thinking if there was something there, I could run power wires behind and out of sight!
View attachment 15912 Was or is there any trim pieces on the inside that run up the sides of the windshield ? I have 3 holes on each side that look like factory holes? I was thinking if there was something there, I could run power wires behind and out of sight!
Yes, there is a plastic trim that goes from the top, down to that rubber bump out by the black screw on the tan dash tab, and it curves with the windshield where that red wire is. Both sides.
There should be a square plastic trim piece against the windshield frame that acts a the seal for the door gasket. Is that what we are talking about. Later Jeeps I believe had a trim piece on the inside where his finger is pointed.
My old 97 had them as well, and my 06 does too. I think someone posted a Ebay link. Shouldn't be too hard to find there, or like the others said, find a wrecking yard, you'd be surprised at what you can find.
