Recently my 2005 TJ (only 57,000 miles) died while driving. After a tow home found it had blown the fuel pump fuse. I measured the resistance of the terminal at the relay to ground and it looked like a short.
I dropped the tank so I could take the connector off the pump. As far as I can tell on this model the harness is one piece up to the relay. With the connector off the circuit was open as I would expect. Measured the resistance at the pump at less then 1 ohm. So I replaced the pump with what looks to be a genuine Bosch. Buttoned everything up and — it blew the fuse again. Resistance at relay - shorted.
Spent a day tracing the wire with my circuit tracer looking for the short and it appears good back to the pump.
Dropped the tank again, pulled the connector off the pump - short is gone. WTH? defective pump? Found that hard to believe so I bought a loose connector and hooked it up to a small 12v battery and connected it to the fuel pump (through a fuse just in case) and bingo - pump ran fine.
Hooked it back up and now it starts fine. Generally I'm pretty good with electric. but I don't trust it. As we all know an intermittent short is the worst.
Anyone ever run into something similar? Any hints?
On another note - after 20 years all the wiring and connectors are getting brittle. If I could find new harnesses I would replace them all as I am hoping for another 20 years out of it.
Thanks
Thanks
