Ok all I have a 2005 Wrangler 4.0 RHD (if it matters) and it has an intermittent miss on multiple cylinders. I have checked / replaced the coil rail, New spark plugs (Autolite DBL platinums), looked under the cap of the oil pump drive assm, Did a compression check cold/hot Cold 160-180 / Hot 150-180, Checked fuel pressure 60 psi and still have the issue. It stutters upon takeoff like its only hitting on 3-4 cylinders and will eventually pick up and go. At highway speeds it acts kinda like the GM active fuel management and drops a few cylinders and eventually picks them back up. This is all random like I have a gremlin under the hood flipping a switch on / off as he pleases. I am now bald from pulling my hair out so any help would be great!
Also have checked for vacuum leaks and have fixed any I have found.
Thanks in Advance!
Jeremy
Thanks in Advance!
Jeremy
