Hey everybody,
I've got a minor issue I'm trying to diagnose:
When I start cold, the engine idles fine for 30-45 seconds, then the RPM dip and fluctuate (like its about to stall) for 10-15 sec, then it goes back to a good smooth idle. It does the exact same thing if I drive around, stop for 15-20 minutes and restart. If I restart within a few minutes, no problems.
Its a 1997 w/2.5L and 122k , no CEL, runs well and just passed smog w/great numbers. I've changed the plugs, wires and cap.
My first idea was that it was a bad fuel pressure check valve/regulator, but it seems like the exact same amount of time cold or warm, so probably not a fueling/vapor lock issue (?)
I'm thinking either an O2 sensor getting warmed up, or maybe an IAC/throttle body needing cleaning?
any ideas on a fix before I throw parts at it?
thanks!
robert
thanks!
robert
