Background
I have been on the hunt for a TJ for the past few weeks after my son totaled my car. I have gravitated to a Jeep TJ to get something a bit more durable for a teenager, it seems pretty straight forward mechanically, and will be fun for the wife and I to drive. I posted a thread in the wanted section, but have been looking locally and beyond for a reasonably priced, rust free Jeep. I have learned a lot on this forum so far, and took my first two test drives today.
Jeep #1 2006 X model $8,500
4.0 AT
136,000 miles
Lift with 33" tires
Soft top with half doors
I thought this one was going to be a winner. Pics of car body and frame looked really clean. I checked the history and it looks like it resided in North Carolina until 2015. I was super excited as this might be an elusive rust free frame specimen near me! Things changed a bit when I saw the car first hand.
The body and outside of the frame was pretty clean with no body rust and minimal surface rust on the frame & suspension. When I probed my finger in the hole, the inside of frame felt ok-ish as I could feel some rust flakiness on the bottom of the frame but it was still solid. I bought a cheap inspection camera and ran it inside the frame. It confirmed the presence of some internal rust. The internal presence of rust was a bit concerning, but could possibly be slowed with an extreme cleaning and protective coating.
The interior was ok. Water was present on the front passenger floor. Soft top windows were getting pretty cloudy and probably need replaced.
Mechanical inspection turned up the following issues: bad heater core (currently bypassed), radiator possibly leaking (although supposedly just replaced a month ago.), and a leaking rear main seal. The check engine light was on (I assume it is for faulty O2 sensors).
The drive seemed ok. I got it up to about 60 MPH and no wobbles were present. Brakes were pulsing, so probably warped rotors.
Seller was pretty firm on price, even after I mentioned it needed a considerable amount of mechanical work (heater, main seal, O2 sensors, brakes, new windows/top, and frame attention.
Current verdict - PASS
Jeep #1 2005 X model $8,500
4.0 6-Spd
100,000 miles
Soft top with full doors
Bone stock
I didn't have a lot of hope for this one. The VIN showed it's life residing solely in Ohio. Pics of the frame were a bit suspect.
The body is in decent shape with a small dent and scratch in the hood (painted with touchup paint to prevent rusting). Soft top and windows appeared to be ok. Some surface rust was on the underside of the body. It needs attention, but doesn't look to be at risk of rust through yet.
The interior was in good shape. The carpet had been removed and replaced with rubber flooring. There was some water on the front passenger floor area, but no rust.
The frame was surprisingly nice. There was very little surface rust. Most importantly I could not feel any rust inside the frame. My inspection camera confirmed the inside to be in pretty clean condition with just a minor amount of superficial surface rust. While the frame is in great condition, there is a lot of surface rust on the drive shafts, engine components and some of the under-body hardware.
Mechanically, the big issues are a ticking sound from the engine that disappears / becomes intermittent when the engine warms up, several oil leaks from the main seal, transmission end seal and differential seals and a check engine light. It is also in need of new tires. It is also Other than that, it ran great.
It drove fine. The only issue was that the 4wd light did not come on when I shifted to 4wd HI.
This buyer is also fairly firm on price (willing to come down a little). However, it needs tires, ticking sound diagnosed, engine/transmission/differential seals replaced, and check engine light issue fixed.
Pics are posted below.
Current verdict - Still in play (seems to be an unmolested cream puff), but concerned about price
WHAT ARE YOUR THOUGHTS?
4.0 AT
136,000 miles
Lift with 33" tires
4.0 6-Spd
100,000 miles
Bone stock
